Spin-offs [again]
Postby cbenenax » Mon Aug 03, 2020 1:17 pm
Sorry, but I have read the documentation and several entries on the board and I still can't make this work.
BEP spun off BEPC. They did it with the equivalent of a 5-for-4 stock split, with all the new shares in BEPC. This is a tax-free transaction. It's only purpose was to create standard C-Corp shares (BEPC) each of which will receive dividends equivalent to a unit in the original MLP (BEP).
THe original shares were bought in a single transaction. I entered 1/5 of the total cost of that transaction (minus various ROC distributions) as the cost basis of the new shares. I expected the Ave. purchase price of all shares (BEP and BEPC) to now be the same, namely the total cost basis divided by the total number of BEP and BEPC shares. The value shown in my report is as expected (24.04) for the new shares, but the cost of the old (BEP) shares was not adjusted (is still 30.96).
The transactions added by the wizard for BEP are:
BEP transactions
ScreenHunter_272 Aug. 03 13.12.jpg (11.49 KiB) Viewed 2695 times
For BEPC:
BEPC transactions
ScreenHunter_272 Aug. 03 13.14.jpg (8.38 KiB) Viewed 2695 times
cbenenax
Postby Mark » Mon Aug 03, 2020 2:03 pm
Hi cbenenax,
Do you still have BEP, or did this just convert all BEP shares to BEPC? If you don't have BEP anymore, you don't need to use the spin-off wizard. On the date of the spin-off just record a split with a ratio of 5 for 4, and change the name/symbol/CUSIP as appropriate.
Postby cbenenax » Mon Aug 03, 2020 2:23 pm
I received 1 new share of BEPC for every 4 of BEP I hold. I still have the same number of shares of BEP as before. The price (and presumably the cost basis) of all shares went down to leave the capitalization unchanged.
cbenenax
Postby Mark » Mon Aug 03, 2020 3:40 pm
In this case, yes, you do need to use the spin-off wizard. Your tax cost basis in BEP will be reduced by the amount of the Return of Capital distribution ($6911.60). What field were you looking at where the BEP cost basis was not being adjusted?
Postby cbenenax » Mon Aug 03, 2020 5:59 pm
Avg purchase price-C in reports:
ScreenHunter_272 Aug. 03 17.58.jpg (8.12 KiB) Viewed 2688 times
cbenenax
Postby Mark » Mon Aug 03, 2020 7:50 pm
That is a simple average of what you paid for each share currently owned. It isn't a tax basis, and isn't reduced by the Return of Capital distribution. To see your tax basis per share (which is reduced by the RofC distribution), see the field:
Tax basis per share, Assigned Method
Postby cbenenax » Mon Aug 03, 2020 8:10 pm
Yes, that did it. Thanks
cbenenax
