Bulk Reconcile
Postby ricbertsch » Wed Mar 24, 2021 5:46 am
We are using Advisor and have a question regarding the bulk reconcilation. We download and import from 2 sources, DST and TD Ameritrade Instl. There are only a few DST accounts. We maintain following Sub Portfolios: Managed, UnManaged and Closed. I am only concerned on The Managed. In this Sub Portfolio (Managed) are each client and then each client has a Sub Portfolio for each account registration and account number.
My question is:
When bulk reconciling we will always have the few DST Accounts pop up as we are using the TD Ameritrade File to do so. Then we will get the 5 or so Portfolios that are holding DST accounts pop up as No Statement. It hasn't really been a problem but I was wondering is there a way to mark those DST Accounts within their Properties as exceptions to being reconciled?
Richard G. Bertsch CFP(tm)
ricbertsch
Postby Mark » Wed Mar 24, 2021 7:52 am
Hi ricbertsch,
No, there isn't, unless you created another level of hierarchy, like this:
Code: Select all
- Master
  - Managed
    - DST
    - TD Ameritrade
  - UnManaged
  - Closed
and then you could choose at what level you bulk reconcile, so you're only seeing the appropriate accounts.
Postby ricbertsch » Wed Mar 24, 2021 8:04 am
Thanks Mark, But since we merge all sub portfolios for reporting and fee calculation per client it is probably best to keep it as it is. I was hoping that I was missing a way to check a block not to reconcile on the Sub-Portfolio Properties.
Ric
ricbertsch
Postby Mark » Wed Mar 24, 2021 8:13 am
Hi Ric,
Okay, just an idea... You would still have the ability to run reports at the Managed level in this situation.
