When using the .csv file from a data vendor (Quandl's SEP package in my example) as the "<local file>," is it possible to specify the import format string like in the "Import / Prices / Generic" function?
Thanks for reviewing my question.
Using Quandl's SEP file as the <local file>
First of all, very glad to have found FM a week ago.
![]() When using the .csv file from a data vendor (Quandl's SEP package in my example) as the "<local file>," is it possible to specify the import format string like in the "Import / Prices / Generic" function? Thanks for reviewing my question.
Hi davidlowe,
Sorry, no, when using the "<local file>" quote server, the supplied pricing file should contain data in either of these 2 pre-defined formats: SYMB,MM/DD/YY,NAV SYMB,MM/DD/YY,NAV,OO,HH,LL,VV You can't currently choose your own format, like you can when you use the generic price import. This would probably be a good improvement... Also, Quandl is one of our supported quote servers, maybe you can just use that to retrieve your data instead of downloading/importing? See: https://www.fundmanagersoftware.com/intrtv.html#Quandl
Thanks, Mark, for the quick reply.
So far, my experience with using Quandl's free quotes and historical has been "sub-optimal." For the last week of using the application, the mutual fund pricing was non-existent and the stock quotes have been hit-and-miss. Since I already have been paying for the premium data, the logical course action seems to be trying to leverage them for FM if possible. It is not a problem for me with the pre-defined format for the <local file> option -- I just need to write a Python script to pre-process Quandl's premium data before feeding them to FM. I just did not want to miss anything obvious before I go and write the script. Again, FM looks good for what I need to do, so I look forward to working with it with the data available to me.
Return to Prices and Transactions Who is onlineUsers browsing this forum: No registered users and 3 guests |
