Yahoo Update Issues
Postby jnewton » Mon Sep 27, 2021 12:50 pm
For the past week, I have had problems updating from Yahoo. Historical seems to work a bit better, but not a complete update. Suggestions? Thanks
jnewton
Postby Mark » Mon Sep 27, 2021 7:46 pm
Hi jnewton,
Can you provide a specific example of a ticker symbol that won't update, or that updates incorrectly from Yahoo? Are you using the latest quote module (562)?
Postby jnewton » Mon Sep 27, 2021 8:25 pm
Yes using module 562
Ticker Examples: AAPL last update 9/24, ABT last update 9/24, BAC last update 9/24.
These were updated on 9/25 using HST icon (Yahoo-historical)
Internet retrieve settings are set on <Default Server>
PRC icon in toolbar says YAHOO
jnewton
Postby Mark » Mon Sep 27, 2021 8:28 pm
Hi jnewton,
I just now test retrieved AAPL from Yahoo and it correctly retrieved a price for 9/27. Here are some things to check:
1) Is your investment enabled for retrieve? Check "Investment Properties... / Internet Retrieve".
2) How are you determining the last price was for 9/24? Where are you looking exactly?
3) If you look under "Help / Logs / Price Retrieve..." do you see it request a price for AAPL? It should look something like this in the log:
Code: Select all
Retrieving from server: (YAHOO)
   Requesting: "AAPL"
   Updating: "AAPL"
      1 -> AAPL: 145.370000 on 9/27/2021
Postby jnewton » Mon Sep 27, 2021 9:13 pm
Yes Investments are enabled.
Getting price dates from each position Price history in the Portfolio position detail
Looked at Price logs for last several days many requests show up properly in the log but are not reflected/updated in the price history.
For example: ABBV is first stock requested. In Price Log: 107.72 on 9/27which is correct. But price history shows 107.07 on 9/24. 9/27 prices do not show.
Others such as AAPL, ABT, and BAC are not in the 9/27 price log or price history
Prices worked fine on 9/22. 9/23 about 20 out of about 150 prices didn't show up in Price History properly. 9/24 situation reversed only about 20 of 150 downloaded properly. During that time updated price module and updated program to latest release. To be clear, problem was occurring before updating but updating did not correct issue
jnewton
Postby jnewton » Mon Sep 27, 2021 9:21 pm
Here is detail for ABBV from Price History
Date Close Shares Value Open High Low Volume
9/24/21 107.0700 500.000 53,535.00 106.8700 108.0500 106.4400 5,835,600
9/23/21 107.3600 500.000 53,680.00 106.9900 108.2700 106.6500 5,847,000
9/22/21 106.4100 500.000 53,205.00 107.0100 107.5800 105.9300 6,220,546
Here is Price Log
Updating: "ABBV"
1 -> ABBV: 107.720000 on 9/27/2021
Also here is part of 9/27 request:
Requesting: "ABBV", "ADT", "OGN", "AIG", "VTRS", "ALC", "AMRN", "AMGN", "BBBY"
here is 9/22 request:
Requesting: "AAPL", "ABT", "ABBV", "AES", "AIG", "AIG-WT", "AMZN", "AMGN", "FOLD", "APC", "ARRY",
You'll notice about 2/3rd of the 9/22 request are not in the 9/27 request
jnewton
Postby Mark » Tue Sep 28, 2021 7:53 am
Hi jnewton,
To keep things more manageable, let's focus on a single investment. It looks like ABBV was updated, but in your data of the Price History it is not showing. Where are you viewing this Price History? In the Data Register under the data type of "Prices"? Are you sorting the Data Register by date? Notice you can click on any column's header in that list, and it will sort by that column. If you're not sorting by date, it may be recorded, but you won't see it at the top of the list.
Postby jnewton » Tue Sep 28, 2021 9:08 am
Yes I am viewing the prices in the data register and yes they are sorted by date.
A couple of things: I changed the default server this morning to: Yahoo (RealTime) and it looks like things have updated.
Also I have a lot of 'dead stocks' and old portfolios that are still active. Wondering if turning off updates on these stocks and portfolios would help.
jnewton
Postby Mark » Tue Sep 28, 2021 9:22 am
Hi jnewton,
You can go to "Investment Properties... / Internet Retrieve", and turn off "Retrieve price" for any investments you don't want updating. Also, you can use "File / File Operations / Hide Sold Investments..." which can also turn off the price retrieve option for your sold investments.
Postby jnewton » Tue Sep 28, 2021 9:40 am
jnewton
