by dellwo » Sun Apr 19, 2009 10:54 am
I'm trying to create a sub-portfolio for my American Funds retirement account. I finally found the fund number and figured out the user id is <Fund#>,<SSN> with the brackets. It seems to login but "fails to retrieve portfolio". I've tried several formats for the Account Number field. With and without bracket, dashes etc.
Any tips?
Thanks, Joe
dellwo
by Mark » Sun Apr 19, 2009 12:31 pm
Hi Joe,
Our tips page:
http://www.fundmanagersoftware.com/tint ... ican_Funds
mentions the user ID is:
<fundnumber>,<accountnumber>
Maybe the accountnumber is the same as the SSN?
Do you get any errors when retrieving? If you're not sure of the account number you can leave it blank. When Fund Manager connects to the server and logs in, it requests a list of account numbers for that login. It will present you with that list if one of the account numbers does not match your recorded account number.
by dellwo » Sun Apr 19, 2009 1:46 pm
I just get "Failed to Retrieve Portfolio".
I've been using the SSN for the account number.
I just tried leaving it blank but got the same error.
I'm not positive about the account number. The only possibilities on the statements are PlanID and Participant SSN. I can't find any other possible numbers.
dellwo
by Mark » Sun Apr 19, 2009 2:25 pm
Hi dellwo,
Do you have other accounts at any other brokerages that retrieve okay? If you look at the log files, do you see anything that might shed some light on what the problem is? You can find information on the log files at the bottom of this page:
If you'd like, you can mail us those log files, and we'll take a look.
by dellwo » Sun Apr 19, 2009 2:39 pm
It works for Fidelity, ETrade, TRoweprice, Vanguard...
I don't see anything in the logs.
I'll PM you with the files.
Thanks, Joe
dellwo
by Mark » Sun Apr 19, 2009 2:50 pm
Hi Joe,
Go to our 'email contact form' here:
Submit any simple message, and you'll be presented with a regular email address you can use to attach the log files.
by Mark » Sun Apr 19, 2009 3:44 pm
Hi Joe,
Received your log files, thanks. The problem is that you have the angled brackets in your user ID. Instead of:
<aaa>,<bbb>
you should just have it like this:
aaa,bbb
You don't want angled brackets in there. Those are just in our tips page, as something that surrounds a variable.
by dellwo » Sun Apr 19, 2009 4:40 pm
I added those because without them it said "signon invalid". It seemed to get further with the brackets added.
So, I still don't know what login information it requires. I can log in to the website fine. I guess I'll just do FM manually.
Thanks, Joe
dellwo
by Mark » Mon Apr 20, 2009 8:33 am
Hi Joe,
With the angled brackets it is causing the request to become incorrectly formatted. The OFX format uses angled brackets, as it is an XML formatted file. Adding angled brackets to your user ID makes it an invalid request, and you're not even getting a login attempt. (Fund Manager should really escape those angled brackets when sending the request, but it isn't currently.) I would suggest contacting American Funds and asking them for help on what your user id should be to retrieve transactions. It may very likely be different than your login credentials for their web server. They are 2 different servers.
