Edward Jones TRN glitch
Postby pdgood » Thu Jan 05, 2023 12:05 pm
As of 1/1/2023, after five years, I have an problem! The data comes in 'summed' for each investment instead of separate for DIV, STCG,and LTCG.
EJA's tech suggested "unlink\relink". Before I do, what is you idea?
Thank you,
Phil Garner
pdgood
Postby Mark » Thu Jan 05, 2023 1:28 pm
Hi Phil,
I would suggest retrieving this account for a date range that covers these transactions, and then look at "Help / Logs / Transaction Retrieve (Parsed)..." to see if these transactions are separated out by type, or combined into 1 transaction? You can cancel the retrieve, and then go look at the log file.
Postby pdgood » Thu Jan 05, 2023 3:40 pm
Thanks for the 'road map'. The logs have 15 different *.txt files. Where do I start? What do I look for?
pdgood
Postby Mark » Thu Jan 05, 2023 6:01 pm
Hi Phil,
If you just retrieve one account, and then select:
that should open up the "xmldump.txt" log file. There is only 1, and it contains the parsed log of the most recent transaction retrieve. It is in a more human readable format that the "raw" version.
Postby pdgood » Thu Jan 05, 2023 10:05 pm
Thanks! Mark
pdgood
Postby pdgood » Fri Jan 06, 2023 1:45 pm
Hi Mark
I am sending additional info. Will this tech support be available over the week-end?
pdgood
Postby Mark » Fri Jan 06, 2023 3:27 pm
Hi Phil,
Yes.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
