Importing Transaction Date Error
Postby gmow » Thu Feb 23, 2023 9:26 am
I get the following error
Error Importing Line:
Reason: Date was not found
Any suggestions? File is attached
Feb 22 2023 v1.csv
(297 Bytes) Downloaded 223 times
gmow
Postby Mark » Thu Feb 23, 2023 9:51 am
Hi gmow,
Make sure you are using the format string:
ED,SYMB,TRAN,ANUM,BNUM,CNUM
Notice, the first line in your CSV file doesn't need to have the format string. The error message you're getting is telling you that it couldn't import that header line, but the rest of the lines will import if you use the above format string.
Postby gmow » Thu Feb 23, 2023 11:34 am
Mark wrote:Hi gmow,
Changed $ANUM to ANUM, removed the header line. Still getting
File to Import: c:\users\glm\onedrive\fund manager div import\feb 22 2023.csv
Input Format: ED,SYMB,TRAN,ANUM,BNUM,CNUM
Error Importing Line: 20210322,ARE.TO,DIST_D,0.18,0,0
gmow
Postby Mark » Thu Feb 23, 2023 2:13 pm
It looks correct, and it works okay here. I notice the filenames are a bit different. Are you sure you posted the exact same file you're importing?
Postby gmow » Thu Feb 23, 2023 2:22 pm
Mark wrote:It looks correct, and it works okay here. I notice the filenames are a bit different. Are you sure you posted the exact same file you're importing?
File attached
Feb 22 2023.csv
(30.12 KiB) Downloaded 223 times
gmow
Postby gmow » Thu Feb 23, 2023 2:24 pm
File attached
My date format in general preferences is M/D/Y
Could this be an issue?
gmow
Postby Mark » Thu Feb 23, 2023 2:50 pm
Hi gmow,
The issue is the CSV file is saved with UTF-8 BOM encoding, so there are 3 non-visible bytes at the beginning of the first line. If you re-save it with ASCII or plain UTF-8 (no BOM), that should correct it. I've done so, and attached your file here.
Feb 22 2023_ascii.csv
File resaved with ASCII encoding
(30.12 KiB) Downloaded 189 times
Postby gmow » Thu Feb 23, 2023 3:06 pm
Thank you, works perfectly
gmow
