Delete Multiple Transactions
Postby jskahan » Thu Oct 05, 2023 11:28 am
I'm importing several years of transactions (via generic format). I'm generally doing a month at a time then checking with my previous software to make sure shares and values are accurate after import and if not tweaking my code to fix the issue.
After I spot an error I'd like to delete the month's worth of data that I just imported so I can re-import the corrected data. When I go to data register I seem to only be able to do this one investment at a time rather than selecting all transactions from that month - is there a way to select all transactions?
jskahan
Postby Mark » Thu Oct 05, 2023 12:13 pm
Hi jskahan,
Sorry, no, there isn’t a way to delete transactions from multiple investments at once. One idea would be to save before your import, and then if you decide not to keep what you just imported, you can exit without saving. See the automatic save on exit options under the top level “Options” menu. Turn those off and then exit, and say no when prompted to save.
