Retrieve ETF prices from Mornistar IT does not work
Postby giancarlo.dibetta » Fri Dec 29, 2023 8:17 am
Hi Mark
I am successfully using Morningstar IT to retrieve Mutual Fund prices and it works.
However retrieving ETF prices from Morningstar IT fails. All of my ETFS are failing to update.
For example the following Ishares ETF
iShares $ Floating Rate Bond UCITS ETF USD (Dist) ISIN code: IE00BZ048462
Symbol : 0P0001BTXL
generates this error
WARNING - Unable to update: "0P0001BTXL" (iShares $ Floating Rate Bond UCITS ETF USD (Dist) in Investments/INPS + NON INPS/ETF 2022)
this is the page in Mornigstar IT where the price can be manually retrieved:
https://www.morningstar.it/it/etf/snaps ... 0P0001BTXL
Any ideas or anything I should correct in my configuration ?
Giancarlo.
giancarlo.dibetta
Postby Mark » Fri Dec 29, 2023 10:50 am
Hi Giancarlo,
The server "Morningstar IT - Funds" only works on traditional funds, not ETFs or stocks. If you look at a fund like this:
https://www.morningstar.it/it/funds/sna ... F00000PWXI
you'll see it has "/funds" in the URL. This is where FM is going, and the ETFs on Morningstar's site go to a different URL, like the one you showed, that has "/etf" in the URL instead. It is something we could add support for, but it isn't currently supported. You might try another server that has good international coverage, like Yahoo, Stooq, or FondsCheck. Links to all our supported quote servers are here:
https://www.fundmanagersoftware.com/intrtv.html
so you can use your web browser to see if any of these servers offer the quotes you're after before putting them in Fund Manager.
Postby matteopeo » Sat Dec 30, 2023 2:07 am
Hi Giancarlo,
I encountered the same problem long time ago and switched to the Wall Street Journal and Wall Street Journal (Historical) servers for ETF internet retrieve information.
They have correct current pricing and go back several years in their historical database for UCITS ETFs traded in Europe and London. This might save you some time in trial and errors (I tried various servers before, yahoo in primis, and found some not to be very reliable).
Cheers,
Matteo
matteopeo
Postby Djobydjoba » Sat Dec 30, 2023 6:44 am
Financial Times is an excellent server for European ETFs and mutual funds too.
Postby giancarlo.dibetta » Tue Jan 02, 2024 2:28 am
Hi Mark
Hi Matteo
Thank you both for your suggestions. I have been able to retrieve all my ETF quotes from the Wall Street Journal server. It works well!
Thank you again and have a Wonderful New Year!
Giancarlo.
giancarlo.dibetta
Postby Arrow » Tue Jan 02, 2024 12:15 pm
giancarlo.dibetta wrote:Hi Mark
Hi Matteo
Giancarlo.
Hi Giancarlo and Matteo.
I do agree with what has been written.
I would like to share my experience that has cost me a great deal of time
as I found that to use Fund Manager for Italian costumers is rather cumbersome.
1. Wall Street historical is much more reliable than Yahoo.
2. If you have the pro or Advisor version Yahoo (if quotes are avalilable)
is better for intraday update because it has a 15 minutes delay rather
than 20 minutes of Wall street.
3 . If you don't find quotes of investments that can't be automatically
updated I advise you to dowload historical data from Sole24 web site
and in many cases they go back up to10 years.
https://mercati.ilsole24ore.com
I copy here the procedure that I follow and the string that you must write in FM for the generic import file that I wrote with the main help from Mark
1. SCARICARE FILE CSV DA PAGINA SOLE 24ORE
2. APRIRE FILE VUOTO EXCEL
3. MENU DATI IMPORTARE FILE TESTO
4. DELIMITATO FLAG DATI CON INTESTAZIONI
5. DELIMITATORI
a. SOLA VIRGOLA (NO TABULAZIONE) E CONTROLLARE A DX, O “(VIRGOLA O VIRGOLETTE)
b. CONSIDERA DELIMITATORI CONSECUTIVI COME UNO SOLO
6 DOPPIO CLICK DATA CORRISPONDENTE A COSA APPARE
7 APRRE FILE CSV E CANCELLARE COLONNE SUPERFLUE
8. controllare simbolo decimali
8. SALVARE COME TXT DELIMITATO DA TABULAZIONI
9. Aprire file TXT PER VERIFICARLO
FM STRING
"OO","HH","LL","NAV","VV","YY-MM-DDTXX
By the way in order to have less problems I do use Fm with the Options -general preferences
Number format Us format i.e 1 thousand = 1,000.00 .
Have a nice 2024 year
Antonio
Arrow
Postby giancarlo.dibetta » Wed Jan 03, 2024 2:14 am
Hello Antonio
thank you for this additional piece of information.
I will also try using Il Sole 24 for historical price retrieval.
Kind regards
Giancarlo.
giancarlo.dibetta
