Transaction Import Start Date
Postby williamg85 » Wed Feb 21, 2024 1:59 pm
In 2023 after TD was bought by Schwab, I had FM downloaded the transactions. For some reason all the accounts downloaded transactions as if the whole account was sold twice, throwing off everything.
I went through all the transactions manually and deleted the "sale's" that were causing me to be out of sync and then reconciled all accounts.
Since then, any time I go to import transactions the start date automatically sets itself to Aug. 2, 2023 instead of the last date that I ran the import.
Any help on this matter is greatly appreciated.
williamg85
Postby Mark » Wed Feb 21, 2024 4:12 pm
Hi williamg85,
This default start date is memorized on a per sub-portfolio basis, and stored in your *.mm4 portfolio file. So, make sure are starting the transaction retrieve at the same sub-portfolio, and are saving your portfolio (File / Save Portfolio). This should cause the default start date to be initialized to the date you last retrieved.
Postby williamg85 » Wed Feb 21, 2024 4:15 pm
Got it!
Thank you!
williamg85
