Controlling "Update Price When Retrieving Transactions"
Postby DukeWeston » Thu Apr 11, 2024 6:42 am
[FM 2024.18.2.100]
I would like to modify (turn off) this setting on my existing investments but I suspect it is going to be tedious.
The global setting dialog "New Investment Price Retrieve Defaults" has a button for "Apply settings to existing investments" but unfortunately it lacks the checkbox for "Update Price When Retrieving Transactions".
Am I missing some other easy way to do this? And if I'm not, maybe this could be implemented in a future update.
I would add that the button "Apply settings to existing investments" seems out of place on a dialog entitled "New Investments ..." and I was quite surprised when I found it lurking there. Perhaps the dialog title could be changed to encompass existing investments, or the button relocated somewhere more intuitive.
DukeWeston
Postby Mark » Thu Apr 11, 2024 1:26 pm
Hi DukeWeston,
I don't think you're missing anything unfortunately. You would have to do this one investment at a time, unless you're using the Advisor version, which would allow you to do it one symbol at a time with "Edit / Symbol List...".
Understood your points, thanks for the feedback.
