Credits to Cash Missing for Purchased Securities
Postby B2B_Investing » Sat Apr 27, 2024 2:53 pm
I was looking over some regular reports that I run and noticed that cash balances were high. When I investigated I noticed that sometime in January transfers into accounts were being recorded but the matching sells when I purchased securities were not. Do you have a recommendation on where I go to start troubleshooting this?
Jason
B2B_Investing
Postby Mark » Sat Apr 27, 2024 5:39 pm
Hi Jason,
Double check that the sub-portfolio property has a default cash account assigned. Also, if you're retrieving transactions, make sure you have a check mark in the option "Automatically Record Corresponding Entry In Default Cash" checked at the bottom of the "Preview Importing Transactions" dialog.
Postby B2B_Investing » Thu May 23, 2024 7:04 pm
Hi Mark - I thought i had replied earlier. Yep the automatic box was accidentally unchecked. I deleted and re downloaded the transactions and that fixed it.
Jason
B2B_Investing
