Transaction Import
Postby Bsrr » Tue Jul 16, 2024 12:43 pm
I have been able to do Generic CSV transaction imports in the past but I must be missing something obvious on this one because I can't get it to work. Keep getting the error message "Could not find all the specified files in the importing file".
I have attached a portion of the CSV transaction file and below is my input format. Can you advise? Thanks.
SYMB,NAME,ITYPE,ASSET,GOAL,TRAN,MM/DD/YY,ANUM,BNUM,CNUM,MEMO
Stock FM CVS.csv
Transactions to import
(1.38 KiB) Downloaded 143 times
Bsrr
Postby Mark » Tue Jul 16, 2024 4:45 pm
Hi Bsrr,
The reason is you have the $ symbol on figures in the file on the ANUM and CNUM figures, but you don't have a $ in the format string. I'd suggest removing the $ from your numbers in the CSV file. Also, for future reference, you can look at "Help / Logs / Generic Transaction Import..." after a failed import, and it will usually give you some more tips on what went wrong.
Postby Bsrr » Wed Jul 17, 2024 2:33 pm
I knew it would be something easy that I was not thinking of! Thanks very much!
Bsrr
