E*Trade transaction retrieval
Postby hipped1 » Wed Aug 28, 2024 6:43 am
Is anyone else having issues retrieving investment transactions from E*Trade. The process worked fine yesterday, unable to retrieve transactions from any accounts this morning. Message received is Failed to retrieve portfolio.
hipped1
Postby Mark » Wed Aug 28, 2024 11:18 am
Hello hipped1,
If you look in “Help / Logs / Transaction Retrieve (Raw)…” does it have anything helpful? You can email the log file to me if you’d like me to look at it.
Postby hipped1 » Wed Aug 28, 2024 11:26 am
The log file appears to be empty
hipped1
Postby Mark » Wed Aug 28, 2024 4:07 pm
Hello hipped1,
I tested it from here, and it appears to be working, although I'm not testing it with a real account. It is responding with an expected response for an invalid login though. If you're not getting anything in response, then maybe there is a connection issue. Have you tried re-starting your PC?
Postby hipped1 » Wed Aug 28, 2024 6:38 pm
The problem appears to be correlated to a Windows update which I applied earlier today.
August 27, 2024—KB5041587 (OS Builds 22621.4112 and 22631.4112) Preview
One this Windows update was installed, I was unable to retrieve any transactions from E*Trade accounts. The retrieve still worked from Ameriprise and Fidelity accounts.
I did a system restore tonight rolling back this update and I am able to retrieve transactions from E*trade.
hipped1
Postby katlizjen » Thu Aug 29, 2024 5:24 pm
I am currently having the identical etrade transaction connection problem.
katlizjen
Postby Mark » Thu Aug 29, 2024 7:11 pm
Hi hipped1 and katlizjen,
I see the same issue after installing KB5041587 Preview. The issue was only affecting E*Trade as far as I could tell. I'm not sure what the actual problem is, or how to fix it. As this seems to be an optional Windows update for now, hopefully this issue will be fixed before any future non-preview version of this update is released.
Postby Mark » Fri Aug 30, 2024 12:34 pm
We've looked into this some more. E*Trade's OFX server is replying with a 403 Forbidden error for some reason under Win11 with this KB5041587 installed. If anyone has a contact at E*Trade that might be able to help us work through this issue, please let me know.
Postby hipped1 » Tue Sep 10, 2024 7:12 am
It appears this issue has been resolved, I am now able to retrieve transactions with the Windows update applied.
hipped1
Postby Mark » Tue Sep 10, 2024 8:06 am
Hi hipped1,
Excellent, thanks for the update.
