Vanguard Transactione Retrieve Error
Postby Cole » Fri Dec 27, 2024 8:45 am
I'm receiving an error message when retrieving transactions from Vanguard. Schwab and Fidelity still working. I've attached a screen shot of the error message. How can I repair this error?
Cole
Vanguard Transaction Retrieve Error.png (6.26 KiB) Viewed 10038 times
Cole
Postby Mark » Fri Dec 27, 2024 9:29 am
Hi Cole,
I'm seeing an error also with Vanguard today. We'll have to investigate...
Postby Mark » Fri Dec 27, 2024 3:29 pm
An update on what we've found... Vanguard is not working with Fund Manager, but still works with Quicken. Today we have submitted a request to Vanguard for help, and are awaiting a response.
Low level details:
Vanguard's OFX server is responding to Fund Manager with an error message (302 Security Redirect) and re-directing to a non-working page (Location: http://www.vanguard.com/notfound.htm), thus causing FM to report a 12156 error due to the failed redirect.
Comparing Fund Manager's request to the request made by Quicken they appear to be identical for everything we can observe. We most likely need Vanguard's help in identifying why their OFX server is responding this way.
How you can help:
If you have a Vanguard account you may contact Vanguard and let them know you'd like for them to help resolve this issue with Vanguard's OFX server not working with Fund Manager anymore. The more people that tell them, hopefully they will help us investigate.
Postby Cole » Fri Dec 27, 2024 6:26 pm
I will put in request tomorrow. However, I have many of my client accounts are at Vanguard. We are approaching the end of the quarter and end of the year. I need to issue performance reports, reconcile accounts, record transactions for compliance. I have access to my client accounts at Vanguard and can download transactions. If the issue is not fixed before the end of the year, what is the easiest way for to enter in transactions that I have downloaded and import into Fundmanager?
Thank you,
Cole
Cole
Postby Mark » Fri Dec 27, 2024 8:56 pm
Hi Cole,
Thank you.
If this doesn't get fixed in time you can go to the "Download Center" on Vanguard's website. On the "Activity" tab along top there is a link to "Download center" in the upper/right of that page. For the download format, choose the "Quicken" format. Choose the date range and select the desired accounts. It will download to a .QFX file, which you can then import in Fund Manager with "File / Import / Transactions / Open Financial Exchange (*.OFX, *.QFX)". Select the file you downloaded, for all dates, all accounts, and make sure it is set to import into FM portfolio "With Matching Account Number as OFX Account". Usually you would leave on the option to skip transactions already in FM, and create new investments as needed.
Postby Cole » Sat Dec 28, 2024 8:20 am
Thank you Mark. I appreciate the quick response, that solution worked fairly easily. I will continue to call Vanguard to fix the OFX problem.
Regards,
Cole
Cole
Postby dstern54 » Sun Dec 29, 2024 1:28 pm
I am also having problems retrieving Vanguard transactions. I sent a note to Vanguard earlier today. Also the last transaction I was able to retrieve was on 12/20/2024 retrieved on 12/21/2024.
Dave
dstern54
Postby Mark » Sun Dec 29, 2024 2:05 pm
Thanks Dave. Hopefully we'll hear from them early this week...
Postby Cole » Mon Dec 30, 2024 10:32 am
I contacted Vanguard's advisor help line and their personal investor's help line. Hopefully they've received enough requests to quickly resolve the issue. If you receive any updates please pass along the information. Happy New Year.
Cole
Cole
Postby Mark » Mon Dec 30, 2024 11:02 am
Thanks Cole, appreciate that. I'll post any updates here.
Postby Bsrr » Mon Dec 30, 2024 1:52 pm
Gents - I have so higher level support at Vanguard and sent a message into them. Not sure it will help but can't hurt. I can not download either (for the last few days now). Hope this helps somewhat. Thanks.
Bsrr
Postby Mark » Mon Dec 30, 2024 2:13 pm
Thanks Bsrr, appreciate the help... As of now, we haven't heard anything from them.
Postby Bsrr » Tue Dec 31, 2024 3:56 pm
My Vanguard contact did forward on my request for help to the technical team - not sure where or who but FYI. Happy New Year!
Bsrr
Postby quercus » Tue Dec 31, 2024 5:59 pm
Fyi, it's not just Fund Manager. I asked on the Boglehead forum. Same problem is affecting MoneyDance, as well as somebody's homebrew software that uses Python ofxtools.
Technical details from MoneyDance are being discussed here:
https://infinitekind.tenderapp.com/disc ... ion/page/1
quercus
Postby Mark » Tue Dec 31, 2024 6:24 pm
Very interesting, thanks for sharing that. It looks like the same issue being seen by FM. We still haven't heard from anyone at Vanguard. Hope they fix it soon, or contact us...
Next
