importing from captools
Postby Shields » Tue Oct 27, 2009 1:37 pm
importing bond data results in position 1000 times to large
Can't find any way to adjust position size
is there a way to hide old, now zero, balance positions when doing a portfolio value report? Also similarly, to avoid updating these old position prices
Shields
Shields
Postby Mark » Thu Nov 05, 2009 4:57 pm
Hi Shields,
I apologize for the slow reply, this message slipped through the cracks... You probably already solved it, but here is an answer.
Edit the transaction that caused this position in the Data Register. Select "Investments (all)" for the data type, select your transaction, and press "Edit...".
Yes, you can "hide" sold positions, and turn off the option to retrieve prices. You can either do this manually, or with the "File / File Operations / Hide Sold Investments" command. See:
