correct past bond transaction
Postby Shields » Wed Oct 28, 2009 1:17 pm
OK I was able to fix currently open bond "shares" as you suggested. Method doesn't seem to work on closed bond transactions as the transaction actually disappears from data register when "all investments" is pressed.
is it possible to edit "cash" accounts?
Shields
Postby Mark » Wed Oct 28, 2009 1:42 pm
Hi Shields,
You can edit any transaction. If you don't see any transactions listed under the "Investments (all)" data type, then you don't have any transactions recorded for that investment...
You can edit any investment. A cash account is just an investment. Select it from the top of the Data Register, and edit it like you would any other investment.
We have a tutorial on using the Data Register here:
http://www.fundmanagersoftware.com/tuto ... video.html
