Gann Swing Chart
Postby Glenn2 » Fri Sep 03, 2010 9:15 pm
I would like to get Gann Swing Charts out of FM. Is this on your list of enhancements and if so then when do you think it will be available?
Glenn2
Postby Mark » Sat Sep 04, 2010 11:29 am
Hi Glenn2,
Thanks for the feedback. I'm not familiar with these. How do you plan to utilize them? I'm sure we can read about them online. They aren't in our immediate plans, but we can take a look. I try to never give an estimate of if/when a feature will be available, until after it is available. Plans can change, so it is best to avoid predicting until after it is done.
Postby Glenn2 » Sat Sep 04, 2010 2:17 pm
Thanks for your reply. W.D.Gann created the concept of swing charts and they are fundamental to following his trading methodology. The following link on the Australian Stock Exchange provides an overview of his charts. Gann has a large following and yet there are very few software products that do Gann charts. If FM were to provide them then I think you would get alot of interest.
http://203.15.147.66/research/charting/library/gann.htm
Glenn2
Postby Mark » Sat Sep 04, 2010 3:02 pm
Hi Glenn2,
Thanks for the information/link. We can look into this, and consider it for a future version.
