Odd popup menu - Version 11 Beta 2
Postby tktf » Sun Mar 20, 2011 2:02 pm
I just downloaded the version 11 beta 2 and started playing with it. I noticed that a new popup menu sometimes appears when I right-click on an investment and choose either "Properties..." or "Display...". It only seems to appear when my mouse is over a graph window when I click on the menu option. The menu consists of "Scroll Here", "Left Edge", "Right Edge" and some other entries. I've never seen this menu before.
At any rate, once this menu comes up (in front of the Properties window) it's a little confusing. You can't select anything from the menu or close the Properties window with your mouse. You have to press the Escape key.
I'd send you a screen shot, but I don't know how to insert an image in this message.
Regards,
Steven D.
tktf
Postby Mark » Sun Mar 20, 2011 2:33 pm
Hi Steven,
That popup does not sound familiar. I'll send you an email, and you can reply to that with a screen shot.
