Filename not visible in investment properties
Postby fundman247 » Sat Mar 26, 2011 4:21 am
Please refer to the e-mail I sent to the support addy as well as the announcements addy.
In short I wondered if one could not use 2 lines for the path/filename if one goes to the statistics of the properties.
My filenames are always not visible as they are cut off.
Regards.
Remeber and practise it!!!!!!
fundman247
Postby Mark » Sat Mar 26, 2011 10:23 am
Hi fundman247,
Thanks for the feedback. If you put your cursor in that text field, you can scroll it to the right, and see the whole item. It probably would be better to make this a multi-line control though, so you can see it without having to scroll. We'll try to do this for 11.0.
Postby fundman247 » Sat Mar 26, 2011 11:34 am
Thanks for pointing the scroll out. It works perfectly to see the filename.
Cheers.
fundman247
Postby Ivan » Sat Mar 26, 2011 1:08 pm
I concur with fundman247 that the scrolling field is fine as it is. Multiline displays can get ugly, and this way its easy to select and copy the entire field. Certainly not a big issue but just putting in my two cents.
Ivan
Ivan
