Default directory for saving new investments
Postby tktf » Sun Mar 27, 2011 12:55 pm
I have a couple of separate portfolios that I maintain on my system. I keep the portfolio data in separate directories so that I can backup and restore them independently. I noticed that when I switch between portfolios the default directory for saving new investments does not change automatically (I once accidentally saved a new investment for portfolio A in the directory I use for portfolio B). It would be nice if the directory used to save new investments would change automatically when you switched portfolios.
Regards,
Steven
tktf
Postby Mark » Sun Mar 27, 2011 5:39 pm
Hi Steven,
You may consider just keeping all your data in a single folder. It makes things easier. You can still backup/restore independently by using the "File / Backup..." and "File / Restore..." on each of your two portfolios. You may also consider just having 1 portfolio file, and 2 sub-portfolios. This way, you can have all your data available, and just choose which sub-portfolio to graph/report on. You also only have to update prices once, instead of twice.
Postby tktf » Sun Mar 27, 2011 6:35 pm
Your first approach, keeping all the files in one directory, sounds fine to me. I didn't realize that only the files associated with the open portfolio would be backed up.
tktf
