Minor display issue - vers 11 beta 4
Postby fundman247 » Sun Apr 03, 2011 11:05 am
Hello Mark,
I have send some slides and a backup via e-mail.
The problem I have on Vista Home is that while scrolling through investments the date on some investments in a 4 and 9 window format are not displayed.
Also I find that in 4 and 9 window that the ROI is not shown on some investments. By scrolling forward and backwards they do re-appear but then some others could be blank. This problem is not related to specific investments but at random to any one. At times the bottom 2 or 3 do display more consistent.
Regards.
Remeber and practise it!!!!!!
fundman247
Postby Mark » Mon Apr 04, 2011 11:05 am
Hi fundman247,
Thanks for the bug report. I did receive your email and the attachments. I see the problem on your screen shots, but unfortunately I could not reproduce it here, even using your backup data. It looks like a painting/refresh issue, but to be sure, if you select "Window / Repaint Graphs", does that fix it when you see the problem?
If you do these tests in 10.9, can you reproduce the problem there too?
Postby fundman247 » Mon Apr 04, 2011 12:07 pm
I havn't checked vers 10.9 on the PC I used for vers 11 beta 4 tests.
Will give some feedback soon.
Regards.
fundman247
Postby fundman247 » Tue Apr 05, 2011 8:13 am
Happy to say the missing ROI and dates in vers 11 graphs were caused by Vista and FM.
By changing the display settings from Vista to Classic instantly fixed the "bug".
It seems one must not use the newer Microsoft systems but stick with the old - :)
Regards.
fundman247
Postby Mark » Tue Apr 05, 2011 2:56 pm
Hi fundman247,
Glad it seems fixed. I tried switching a Vista system between "Classic" and "Vista" themes, and wasn't able to get it to show this problem in either case. There must be something different on your system than mine, but I'm not sure what it is. I'll keep an eye out for this, in case I'm somehow able to reproduce it.
