Delete investments
Postby Nipse » Thu Apr 07, 2011 5:56 am
I have had a lot of portfolios. I Have deleted most of them through "open Portfolio".
I think I have a lot of *.dat files left from these portfolios. Are there methods to delete the *.dat files not in use?
Best Regards
Nipse
Nipse
Postby Mark » Thu Apr 07, 2011 8:14 am
Hi Nipse,
Here's a method you can use:
1) Edit the properties of an investment, and go to the "Password" tab. Assign a password, and choose "Apply to All Open Investments".
2) Issue "File / Save Investments".
3) Now, you can go look at your investments in Windows Explorer and sort by date modified. Any investments that didn't just get modified were not open. You can delete these older ones without affecting the portfolio file you just had open.
4) If desired, un-do the password assignment from step #1.
Postby Nipse » Thu Apr 07, 2011 9:15 am
I will delete all *.dat files. Can I also delete .INV, .DIV. PRC and .MSC files without problems
Nipse
Postby Mark » Thu Apr 07, 2011 9:53 am
Hi Nipse,
Yes, you can delete all those files, they are not used by recent versions of Fund Manager.
Postby Nipse » Thu Apr 07, 2011 9:59 am
Mark, thank you for yours always fast reply.
Bjarne
Nipse
