Report Header Suggestion
Postby cheapsk8 » Wed May 11, 2011 11:55 am
I know that the Logo/header overlap issue has improved by shrinking the logo.
However, I think it would be helpful to have the logo as a separate header. In effect, have two headers. One for the logo that can appear as a banner at the top of the page and then the various specific report headers below that.
The problem I have now is that the report header text is formatted for centering on the page and is limited in length by the logo to the left. If the line of text is too long, it is cut off on the right hand side in order to remain centered. So, no more overlap, but now the text is cut off.
Let me know what you think.
cheapsk8
Postby Customer Support » Thu May 12, 2011 8:57 am
Due to vacation, technical support will be unavailable until Monday May 16th. We will reply to your post on Monday.
Customer Support
Postby Mark » Sat May 14, 2011 9:17 am
Hi cheapsk8,
Thanks for the feedback. Yes, that would be an option we could provide. The drawback is that it would take up additional vertical space, but we could give you the option to choose.
In case you haven't seen it, you can customize how much of the horizontal space you want to dedicate to your logo. See "Options / Report Preferences... / Logo / Limit Width to X% of Page Width". Also, your report headers can be as many lines as you need, so you may want to customize them, so they print additional information on separate lines, so they don't get too wide. See "Options / Report Headers...". Between these 2 settings, hopefully you can adjust things to get everything displayed as you want.
