Search function
Postby Maury56 » Fri Jul 08, 2011 5:12 pm
I am a new user and wish there was a search function for this Forum. Using the Index is not as efficient as searching for a few key words. And often the person making the post did a less than helpful job of selecting what to put into the SUBJECT box.
Maury56
Maury56
Postby Mark » Fri Jul 08, 2011 5:23 pm
Hi Maury56,
There actually are 2 different search tools for this forum. The forum software itself has a search function, if you look along the top of the window. It says "Search", and then "Profile", etc...
There is also a Google search feature that will search this whole Fund Manager site. I find this works better than the forum search feature. To use that, look at the bottom of any window (in the light brown bar), and you will see another "Search" link. Or, you can just go here:
http://www.fundmanagersoftware.com/search.html
Postby Maury56 » Fri Jul 08, 2011 6:06 pm
Opps, my bad. Well, I said I was a new user.
Maury56
