Printing dividend data for a specific stock
Hi Franklin,
Where are you looking at the dividend data? Is this in a report, or in the Data Register? If you're trying to print a report, make sure you select that window to give it the focus, and then choose "File / Print Report".
Hi Franklin,
What command are you using to print? While viewing the distributions in the Data Register window, just press the "Print..." button in the Data Register window. If you select "File / Print / Window" from the main menu, this is referring to a graph window, and will print that instead. Just use the "Print..." button in the Data Register.
Who is onlineUsers browsing this forum: No registered users and 5 guests |
