2 monitors w/ fund manager
Postby frankpazulski » Tue Nov 22, 2011 4:22 pm
Hi Mark, using multiple monitors, any graphs are limited to only one monitor, the one with fund manager is open and it cannot be moved to a 2nd monitor. any suggestions.
Frank
frankpazulski
Postby Mark » Tue Nov 22, 2011 4:31 pm
Hi Frank,
You should be able to move the Fund Manager program to any monitor... Make sure you are moving the top level frame window for the whole Fund Manager application, and not just a graph or report window inside the Fund Manager application. These child windows are only displayed within the top level Fund Manager window.
Maybe you are trying to put a graph on each of your two monitors? If so, you'd first need to size the top Fund Manager window so that it spans both of your monitors, and then the graph windows can each be on their own monitor, but both would still be within the top level Fund Manager window.
Postby frankpazulski » Tue Nov 22, 2011 4:42 pm
Frank
frankpazulski
