Two Line Column Headings
Postby neri » Tue Feb 07, 2012 8:21 pm
Mark-
I asked about this a year ago and was hopeful that this might make it into one of your updates. It would be nice to have two line column headings so that the titles wouldn't truncate as you change the column width.
The only solution today is to change the font size of everything on the sheet, which makes it almost impossible to read.
Any plans for this?
neri
Postby Mark » Tue Feb 07, 2012 8:32 pm
Hi neri,
Which window are you asking about? You can do this now in the Custom report when using the Advisor version. You have full control over all the column headers, and can name them whatever you like, and use two rows for the column heading. If you have the Advisor version, see "Options / Report Column Labels...".
Postby neri » Thu Feb 09, 2012 6:38 am
Sorry. This is in the editor window. For me, its the one I view most.
neri
Postby Mark » Thu Feb 09, 2012 9:01 am
Hi neri,
