New features
Postby samuel » Mon Apr 28, 2008 2:19 pm
I am very pleased with Fund Manager. Thank you for this great software. Nevertheless I have some suggestions for "must have" features:
- ability to draw simple straight lines and comments into the chart
- ability to delete weekends from the chart
thank you
sam
samuel
Postby Mark » Mon Apr 28, 2008 4:54 pm
Hi samuel,
Thanks for the feedback.
You can record trendlines, see:
http://www.fundmanagersoftware.com/help ... lines.html
You can also record notes that display on investment based graphs as markers. Right mouse click on any investment based graph, and choose "Note..." from the popup menu. Make sure you have Note markers on under "Options / Markers".
Postby samuel » Mon Apr 28, 2008 5:08 pm
Thanks Mark
I didnt see that.
p.s I cant find "Options/Marker" but it works anyway
samuel
Postby Mark » Mon Apr 28, 2008 5:12 pm
samuel wrote:p.s I cant find "Options/Marker" but it works anyway
Make sure you are in a Graph window, and you should see a top level "Options" menu command, and then a sub-menu called "Markers" in there.
