Rebalance report with absolute target
Postby gerard » Mon Nov 19, 2012 9:27 am
I'm just started with the FM software, which gives me a lot of information. Great !
In my financial plan i've drawn a line how much money must be invested on a certain time to meet the future obligations.
Therefore on a fixed date I ''l rebalance my portfolio to both a total portfolio value and a target % of assets.
The current rebalance report in FM does only rebalance to target % of assets.
If you can add in the window "Allocation Target properties" an additional field where i could put in the "target portfolio value" on that moment and show in the report the target the actual %, delta % and delta value against this "target portfolio value" this will be very helpfull. The ultimated situation will be where I can define in front " The target portfolio Value" for the coming years. But this could be step 2.
I repeat: I just started working with FM, so maybe this way of working is already possible with FM but I couldn't find this.
Thanks gerard
gerard
Postby Mark » Mon Nov 19, 2012 10:06 am
Hi gerard,
Thanks for the feedback. Do you want to see a value difference for each security, or just the whole portfolio?
One idea would be to use the Rebalance report to allocate your percentages, but compare your actual sub-portfolio total value with a hypothetical model portfolio, where you have entered your target values on different dates into this model portfolio. In this case, you could use the "Portfolio/Investment(s) Overlay / Value" graph to overlay both sub-portfolios, so you can graphically see the difference in your actual versus target value over time.
Postby gerard » Mon Nov 19, 2012 12:50 pm
Thx for your reply.
Yes I would like to see the value difference for each asset categorie.
I tried your suggestion with Overlay/Value graph, this gives a overal view, but it is difficult to retrieve the delta's from the graph for the indivudial asset categories.
Gerard
gerard
Postby gerard » Tue Nov 27, 2012 2:32 am
I've a workable solution.
On the balance moment: I check actual value of portfolio and the value it should have acoording to plan. The difference I temporary add / subtract from the cash account. Then I do the rebalance.
I would be nice if in the futher: you can define a permissible range for an asset class. And if fundmanager detects an out-of range situation you w''l be notified.
Gerard
gerard
Postby Mark » Tue Nov 27, 2012 10:20 am
Hi Gerard,
Glad you found a workable solution, and thanks for the idea on alerts for being out of balance.
