beta 4 crash on report
Postby frankpazulski » Thu Apr 03, 2014 5:57 am
Hey Mark, encountered a crash repeatedly on portfolio performance report. When I change cash flow method to cont with with-distrib from preferences in report setting the system crashes but if I set cash flow from options- report preferences the system works fine. A log file dmg was registered. Would you like further information. I am using beta 4 advisor.
Frank
frankpazulski
Postby Mark » Thu Apr 03, 2014 8:31 am
Hi Frank,
Yes, can you please email us that *.dmp file created when the program crashed? I believe you have our email. Let me know if you don't.
Postby frankpazulski » Thu Apr 03, 2014 8:34 am
Okay Mark, file is on the way.
Frank
frankpazulski
Postby Mark » Thu Apr 03, 2014 2:04 pm
Thanks Frank. We reproduced and then have fixed this bug for the next release.
Postby frankpazulski » Thu Apr 03, 2014 2:08 pm
Thanks Mark, will let you know if I find anything else.
Frank
frankpazulski
Postby frankpazulski » Thu Apr 03, 2014 5:15 pm
Mark, found same crash on Distribution Summary. You probably already know that with our previous correspondence. If not let me know if you need the any dump files. Also google did a split today into 2 share classes. I used spinoff to record, is there any way to not record the transfer as external, as it really distorts cashflow reports.
Thanks again,
Frank
frankpazulski
Postby Mark » Thu Apr 03, 2014 7:26 pm
Hi Frank,
If the crash is happening when you go through "Preferences..." within "Report Settings", then, yes, I would believe this is the same bug. If it is something different, please send me the .dmp file.
Any "Transfer" type of transaction is always considered external. Can you give me an example of which report is getting distorted, and how? Maybe I can offer another suggestion.
Postby frankpazulski » Thu Apr 03, 2014 7:43 pm
Yes Mark, the txin subtotal on investment transaction report includes the transaction of the split of google into A and C shares today. It's recorded as cap rtn on google and txf in for class A shares. Also the crash was related to preferences selected inside report setting, same as the last report. Thanks.
Frank
frankpazulski
Postby Mark » Fri Apr 04, 2014 11:07 am
Hi Frank,
Thanks for the info on Dist. Summary.
How do you want the Investment Transactions report to display? If you want the TxIn to be summed with your "Buys" in the total lines, you can change the "Options / Report Preferences... / Investment Transactions / Report Totals" option to just "Display" instead of "Display Detailed".
