Report Column Width
Postby IanC » Mon May 12, 2014 10:37 am
Reports seem to show with a column width calculated to accommodate the width of all the values in the column of a report BUT the column totals are almost always NOT included in the column width calculation. My column totals are squished and show "..." when the column values shows completely.
Can you fix this one?
IanC
Postby Mark » Mon May 12, 2014 10:41 am
Hi IanC,
Column totals are included in the column width auto-size. Does this happen for all reports, or is there a specific report/field that is not auto-sizing? If you're looking at the report, and choose "Window / Auto-Size Columns", does that fix it?
Postby IanC » Sun Jun 15, 2014 12:46 am
Thanks Mark, Yes, Window / Auto-SIze Columns adjusts the report column widths to make it display correctly.
The option under report preferences does not seem to accomplish this automatically.
Ian.
IanC
Postby Mark » Sun Jun 15, 2014 12:25 pm
Hi Ian,
Column widths are calculated on a per-report type. This means if you have multiple Custom reports, the topmost report will set the column widths for all Custom reports. This may be the cause of why the automatic sizing appeared to not be working. You can see your list of open reports under the "Window" menu. You can close any you're not using, and that should help resolve the problem if this is the reason.
