Sorting alphabetically the category labels
Postby Djobydjoba » Sun May 25, 2014 2:03 pm
Regarding the sort alphabetically command in the Category Labels dialog box, when there is a label beginning with a letter after the U letter ("Volatility" for example), it appears at the end of the list, after all the "unused00" entries (or the after the "user defined 00" entries for Investment Goal - perhaps an inconsistency here ?). Of course I would like that the entry appear before.
I know I can reorder manually after the alpabetically sorting, but to put at the top the last entry I have to clic 80 times...
Any idea ?
Postby Mark » Sun May 25, 2014 2:13 pm
Okay, thanks for the feedback. Maybe we could improve this, by adding a keyboard shortcut so you could hold down Ctrl+<Up Arrow> to quickly move the selected item up the list.
Postby Djobydjoba » Sun May 25, 2014 2:18 pm
Yes, that would be good.
I thought I could rename the "unused00" entries to something like "zzz_unused00", not manually (no thanks), but with an export of the registry, replacement and reimport, but all the "unused00" don't appear in the registry, in particular for the Investment Goal labels (only the used entries appear).
Postby Mark » Sun May 25, 2014 2:22 pm
Try editing one, and then it should show up in the registry... The names of the keys are based on their original default names, like "User Defined 27".
Postby Djobydjoba » Sun May 25, 2014 2:29 pm
OK, thanks. I will wait for an improvement instead of playing with the registry. :mrgreen:
Postby Djobydjoba » Sun May 25, 2014 2:49 pm
Really appreciate the alphabetically sorting by the way. :D
Postby Mark » Sun May 25, 2014 2:53 pm
Glad you like the sorting improvement... Thanks for all the feedback you've provided to help us improve this feature.
