FM9b2 - Graph bug
Postby k_kirk » Wed Jul 30, 2008 11:40 pm
Tried this on portfolio cost and cost / value graphs. Multi currency portfolio. If Exchange Rate adjusted option is disabled X axis shows total value scale displayed but of course the numbers don't make sense. When Exchange Rate adjusted option is enabled the graph representation is correct but the X axis scale numbers are no longer displayed.
k_kirk
Postby Mark » Thu Jul 31, 2008 5:17 pm
Hi k_kirk,
I couldn't reproduce a problem here... Do you mean the Y axis labels are not displayed along the left side, or do you really mean the X axis labels along the bottom? Is your date or range possibly zoomed in too far? Try resetting the scale by pressing Shift-R on your keyboard. Does that fix it?
Postby k_kirk » Thu Jul 31, 2008 7:33 pm
I'm sorry. It was the X axis on the left of course. I see them coming and going. Will try a little and see if I can localize the issue and then perhaps send you an email with screen-shots. Regards
k_kirk
