Weekly MACD and alerts
Postby Nisse » Sat Dec 27, 2014 4:45 pm
I use weekly and daily MACD a lot to analyze investment timing and would appreciate the addition of a “weekly/daily” parameter in FM MACD options. It would also be great if you could toggle between weekly and daily with a simple Ctrl-<whatever> command.
Further, being able to set alerts on MACD signal line crossovers would be great. Having that for both weekly and daily would be awesome.
Happy New Year and thank you for an outstanding product.
Nisse
Postby Mark » Sat Dec 27, 2014 4:53 pm
Hi Nisse,
Thank you, appreciate the feedback/ideas.
Postby pauyo » Tue Sep 22, 2020 2:48 am
Hello,
I too really miss the features suggested by Nisse in his post above. The weekly (and even monthly) charts are really crucial to use the technical analysis effectively. Please consider adding these suggestions. (if not already present?).
I would also like to have the ability to resize the upper/lower graphs in the technical analysis graphs, as the lower graph section is very small in relation to the upper (price line).
Regards,
Paul
pauyo
Postby Mark » Tue Sep 22, 2020 9:42 am
Hi Paul,
Thanks for the feedback. The Technical Analysis graph is only available to plot daily currently.
