Date/Time Format
Postby cllazaro » Sat Dec 27, 2014 10:39 pm
I don't know if this has been brought up before but I couldn't find a topic on the messages boards or a configuration setting in the program. Is there an option to set the program date format as YYYY.MM.DD, and if not, is that feasible as a feature going forward? Also, this may be overkill but would you consider an option of time stamps as HH:MM:SS (24 hour format) for those of us (or maybe just me) who want to enter detailed transaction info?
Carlos.
cllazaro
Postby Mark » Sun Dec 28, 2014 11:06 am
Hi Carlos,
There isn't a date format choice for YYYY.MM.DD, only MM/DD/YY and DD/MM/YY. We can consider adding this support.
For the time, are you looking to record the time of your trade?
Postby cllazaro » Sun Dec 28, 2014 12:48 pm
Hi. Thanks for the quick reply. Yes I'm referring to the execution/trade time stamp. In the Data Register the columns could be "2014.12.31 14:31:00 COLUMN-3 COLUMN-4 etc.." with the option to have a dummy time stamp "xx:xx:xx" if the broker does not provide that information.
Carlos
cllazaro
Postby Mark » Mon Dec 29, 2014 10:08 am
Hi Carlos,
Okay, I understand. Thanks for the feedback/idea.
Postby Nisse » Fri Jan 02, 2015 9:16 am
I second the request for adding YYYY.MM.DD or maybe YY.MM.DD as another date format option.
Nisse
Postby MerrittMarkA » Fri Feb 20, 2015 12:56 pm
I 'third' this request. :)
YYYY/MM/DD is the most sensible date format in use, as it alpha sorts properly, and has a "cleaner" look in columns as all data has the same length. As in February is "02", not "2".
Europeans prefer YYYY/DD/MM which (as a Euro born & raised individual) is just as stupid as the American M/D/YY, as it doesn't sort properly. But as long as you are fiddling under the hood, offering a more complete range of date support makes sense. See Excel, for example.
I use YYYY/MM/DD for everything in my life, and it drives me nuts to look at data in any other format. :shock:
Thanks!
MerrittMarkA
Postby Mark » Fri Feb 20, 2015 1:28 pm
I can confirm this will be available in the next major update...
Postby Nisse » Fri Feb 27, 2015 11:28 am
Great! Many thanks!
Nisse
