Choosing column to sort
Postby fundman247 » Tue Mar 10, 2015 2:17 pm
Please find another point on sorting to try and find a possible enhancement.
When using the same field but with different dates. One can only select one field to use for the sort. Thus only the 1st field can be sorted.
Regards.
Comments on the picture.
Remeber and practise it!!!!!!
fundman247
Postby Mark » Tue Mar 10, 2015 2:54 pm
Hi fundman247,
Thanks for the feedback. Yes, being able to sort by clicking on any column header would be a nice improvement here.
Postby fundman247 » Wed Mar 11, 2015 12:27 pm
Yes you came up with the best solution to click the column heading and add an arrow like e-mail clients indicate.
Regards.
fundman247
fundman247
