Obvious indicator for currency type selected
Postby marathon » Wed Jun 03, 2015 8:22 pm
Hi Mark
This is suggestion for optional simple feature to show in the title bar or perhaps change the background color of the portfolio editor depending if the Exchange Rate Adjuted is turned on or off
Why?
Have multiple currency exposures to worry about and not always the most alert when updating the tool
Easy to forget which is which after a long day and checking the figures.
Been several times had re-check
I know also possible to go to "View" and see if the small tick is marked next to Exchange Rate Adjusted
Why not have a slight grey (or green, or purple??) tinge background
marathon
Postby Mark » Thu Jun 04, 2015 7:24 am
Hi marathon,
I agree it would be better to make this more obvious, and we do have plans to address this in the next major update. I'm thinking more along the lines of a dedicated status bar pane displaying this information though.
Postby marathon » Thu Jun 04, 2015 8:25 pm
great...looking forward to the next update
just consider the use case
it's 10pm after a long day, and need to update another portfolio, eyes are tired and easy to miss things
so the best system is one that is dummy proof
then even i have a chance to use it correctly :-)
marathon
