Open Lots Report - Sort
Postby MRG » Sun Jul 05, 2015 12:21 pm
When I run the Open Lots Report, the following do not sort properly:
1. Distributions (note this one seems to be sorting by % Gain)
2. % Gain (note, as indicated above, I get this one when I sort by Distributions, but here it seems to be sorting by Price Gain)
3. Price Gain (Note this one sorts by Value Gain)
4. Days Owned (although I can get around this one by sorting by Open Date, when I select this one it sorts by Performance)
5. Performance (This one doesn't seem to sort any column, let alone Performance)
1 to 4 all seem to sort the field following on the right.
Michel
MRG
Postby Mark » Sun Jul 05, 2015 12:34 pm
Hi Michel,
We fixed a bug like this in version 2014.13.5. What version are you using? See "Help / About...". The current version is 2014.13.7. If you have an older version, please download the latest from our site here:
https://www.fundmanagersoftware.com/download.html
Postby MRG » Sat Jul 11, 2015 6:02 am
Thanks Mark.
I was on version 2014.13.4. I did the upgrade.
Michel
MRG
