Version 9.X release
Postby HCPierce » Wed Aug 20, 2008 10:56 am
20080820
Mark:
Slight confusion. I'm using 9.0/401/127 (Beta 6). I jumped into this from Ver. 8.4.
Your upgrade instruction says: "If you have never purchased Fund Manager before, see the "new" prices. If you have purchased any version of Fund Manager prior to 9.0 you are eligible for the "upgrade" prices. If you have already purchased any 9.x version you do not need to upgrade, your existing license is valid for all 9.x versions. All prices are US dollars."
Therefore: I've purchased Ver 8 and am using Ver 9.0 Beta 6 so I guess I need to remit the tariff for upgrade to Ver 9.0 ...but if I'm using Ver 9.0 Beta 6 do I need to download the Version 9.0 upgrade release and install it???
Simple things confuse simple minds!!!!
Best regards, H. C. "Chuck" Pierce, Dana Point, CA
HCPierce
Postby Mark » Wed Aug 20, 2008 1:30 pm
Hi Chuck,
Yes, you would want to download the official 9.0 release, and install it over the beta 6 version you're using now.
