Remove return of capital from distributed distributions
Postby Bobo » Fri Feb 03, 2017 11:18 pm
It would be great if I had report field where Return of Capital is excluded from the "Distributed Distributions current" field. Since Return of Capital is not a monetary gain it messes up what I'm looking for, namely how much money I'm making on the distributions I receive. Return of Capital is already reflected in the Tax basis FIFO field which I also use, so I get to see the affects of Return of Capital (ie. lowering my cost basis). It really messes things up when a company splits into two separate companies. In this case I report a Return of Capital for the amount of the spin off in the old company, then I use that amount to record a purchase of shares in the new company. Now the Dist dist-C field shows a huge increase, which doesn't tell me how much money I'm making.
Gary
Bobo
Postby Mark » Sun Feb 05, 2017 9:11 am
Hi Gary,
If you are using the Pro or Advisor version you can write your own equation to exclude Return of Capital. There isn't a "current" version, but there is a "between" version of Return of Capital. The equation would be:
Distdist_btw-RtrnCapdist_btw
Postby Bobo » Tue Feb 07, 2017 12:02 am
I'm using the personal version 2014.13.8.
I don't suppose my request could be added to the next major personal release?
Bobo
Postby Mark » Tue Feb 07, 2017 7:46 am
Hi Bobo,
Thanks for the feedback, we can consider adding another built-in custom field for this.
