TITLES
Postby rkfrost » Fri Mar 03, 2017 12:12 pm
Please can you make it possible to word wrap the titles & column headings so that more columns can be seen with complete headings instead of cutting them
Regards
RAY FROST
rkfrost
Postby Mark » Sat Mar 04, 2017 8:42 am
Hi Ray Frost,
If you use "Window / Auto-Size Columns" that should show your complete column titles, without truncation?
Postby paulk » Sun Mar 05, 2017 7:56 am
Hey Mark
Just to clarify with your response, the auto size will end up increasing the height of a column in a header to accommodate the text correct? I seem to remember trying this with the correlation matrix in the Advisor version and having the program heighten the header column a lot to fit the text. Any way to work around that and change the font sizing for the headers in just one specific report?
paulk
Postby Mark » Sun Mar 05, 2017 9:07 am
Hi paulk,
The auto size does not change the "height" of a column header. It changes the width of the whole column to fit the widest required field, whether that is from the data or the column label.
There is an option in the Advisor version where you can change the column label text. You can put the label text on up to 2 lines. This can also be used if you want a narrower column label.
You cannot independently change the column header font without changing the font for the whole report. You can change the whole report font under "Options / Report Font...".
Postby paulk » Mon Mar 06, 2017 4:57 am
Where is that option in the Advisor version? I can;t seem to find it.
Also, changing the report font under options will apply that change to ALL reports correct? In other words, am I unable to reduce the font of only one report while leaving others large?
paulk
Postby Mark » Mon Mar 06, 2017 8:47 am
Hi paulk,
See "Options / Report Column Labels...".
