by ricbertsch » Mon Sep 11, 2017 7:27 am
Thanks for adding the Allocation Target to the Portfolio Properties.
Is there a possibility of having the Allocation Target on the Rebalance Report defaulting to the Target Allocation Set within the the Sub Portfolio that you are running the report on?
Ric
Richard G. Bertsch CFP(tm)
ricbertsch
by Mark » Mon Sep 11, 2017 1:16 pm
Hi Ric,
Yes, that would be good. We'll do this for the next release.
by ricbertsch » Mon Sep 11, 2017 1:42 pm
Thanks,Mark!
ricbertsch
by Mark » Mon Sep 11, 2017 5:06 pm
Hi Ric, This has been added to Fund Manager 2018 Beta 2. Beta 2 is now available from the Beta page.
by ricbertsch » Tue Sep 12, 2017 12:06 pm
Mark, I downloaded FM Advisor 2018 Beta 2 and when I went to run a Rebalance Report for a Sub Portfolio the Rebalance Report Allocation Target did not default to the Allocation Target set in the Sub Portfolio's Properties. E.g. Client IRA Portfolio Properties Allocation Target is Aggressive. The Rebalance Report for the same Sub Portfolio had a Balanced Allocation Target.
ricbertsch
by Mark » Tue Sep 12, 2017 12:46 pm
Hi Ric,
How did you create the Rebalance report exactly? If you go to "Reports / Rebalance..." it will bring up the "Report Settings" dialog. When you pick the sub-portfolio you want, the "Allocation Target" should change to whatever is assigned to the selected sub-portfolio.
If you were opening a memorized report, or switching to an already open report window, it won't change. You have to go through the Report Settings dialog.
by ricbertsch » Tue Sep 12, 2017 1:31 pm
Mark, that is what I did. I must have misunderstood the update. I thought that when running the Rebalance Report and selecting the Sub Portfolio in the Report Settings that the Allocation Target would default to the Allocation Target set in the Sub Portfolio Properties
ricbertsch
by Mark » Tue Sep 12, 2017 1:46 pm
Hi Ric,
Thanks, I see the problem now too. We'll have it fixed for the next release. It is meant to work the way you've described.
by Mark » Tue Sep 19, 2017 11:03 am
Hi Ric,
Beta 3 is now available, and should correct this issue. Let me know if you see any issues.
by ricbertsch » Tue Sep 19, 2017 11:43 am
Mark, thanks. I did a high speed looksee at a few accounts and found that the correct Target Allocations are reflected in the Rebalance Report. However, for Sub Portfolios with no Assigned Target Allocation assigned in the Portfolio Properties it appears as if I run a rebalance report the Target Allocation defaults to Balance. Not that this matters since we would never run a rebalance report on these portfolios since they are not managed. If they were we would have entered a Target Allocation in the Sub Portfolio properties.
Anyway, we are scheduled to rebalance a number of portfolios in the next week so if we come up with anything I'll let you know.
Again, Thanks this is a HUGE Time Saver.
ricbertsch
by Mark » Tue Sep 19, 2017 1:41 pm
Hi Ric,
Thanks for taking a look. If a sub-portfolio does not have an assigned allocation target, the old behavior is used, which is that the last used allocation target is selected by default.
