Suggestion for the Android app.
Postby DavidJ » Fri Oct 20, 2017 4:10 am
Hi!
I think that it would be better if the (sub)portfolio totals were also visible in the expanded view, and not just in the collapsed view. This would also make at-a-glance comparisons between my portfoliio and a benchmark easier. On my tablet, there's plenty of room in the top ribbon.
David.
DavidJ
Postby Mark » Fri Oct 20, 2017 8:10 am
Hi David,
Thanks for the feedback. Are you talking about adding the subportfolio value on the menu line, where the refresh and settings button are located?
Postby DavidJ » Sat Oct 21, 2017 11:12 am
Yes.
DavidJ
Postby Mark » Sat Oct 21, 2017 2:43 pm
