Minor Problem with Android app on 5.2 in. screen
Postby DavidJ » Tue Nov 07, 2017 12:18 am
Hi!
I'm not sure if this is important, but...
My phone is a Samsung Galaxy J5 2016 SM-J5108, announced 1st q. 2016.
The screen size specifications are: 720 x 1280 px (5.20") 282 ppi
For many of the individual investments, the % sign on the percentage change for the day is chopped off, which is slightly annoying.
I can send you screenshots by email if you want to, to whatever email you suggest. I suppose I could post them here, but it would be complicated because of privacy concerns.
Thanks again.
David.
DavidJ
Postby Mark » Tue Nov 07, 2017 7:56 am
Hi David,
Can you try decreasing the font size to see if that fixes the problem. See the menu button, and then go to "Settings / Font Size".
Postby DavidJ » Tue Nov 07, 2017 10:39 pm
At 12 pt it displays just fine.
Thanks!
DavidJ
