High Resolution and Font Scaling
Postby Tintin » Wed Mar 28, 2018 8:57 pm
The ledger view is fine and scaled via MS Windows, but the icons in the title bar are 'teenee'. Any forthcoming solution?? Using 2880x1620 on a Lenovo W540/541
Tintin
Postby Mark » Thu Mar 29, 2018 7:17 am
Hi Tintin,
Thanks for the feedback. It would be good to provide some higher resolution icons for the toolbar. Currently, the icons are a fixed pixel size, so will be smaller on a higher resolution display. To help this for now, you could turn on "Options / General Preferences... / Toolbar / Show Labels Under Icon".
