Portfolio Manager Feature
Postby HCPierce » Mon Dec 01, 2008 7:18 pm
20081201
Hi Mark:
Before anything else! I wish you a Happy Christmas and a prosperous New Year.
In the Portfolio Manager, I find myself wanting and needing the sum of the value column. Could a final item "Total" be entered in the name column which would cause a summation of the value column to be attached as the last item in the value column of the particular portfolio.
To get worse: Could a .dat file be saved for each portfolio so setup with a "Total" function which would allow graphing the total of this portfolio?
Best regards, H. C. "Chuck" Pierce
HCPierce
Postby Mark » Mon Dec 01, 2008 8:44 pm
Hi Chuck,
Thanks for the well wishes.
A couple of thoughts:
1) Select the next higher level sub-portfolio on the left, so you can see the totals for the lower level sub-portfolios on the right.
2) Create a report, instead of looking in the Portfolio Editor
It may be possible to create such a .dat file in the future, but it isn't a feature we have today. Thanks for the idea.
