Next Major Upgrade?
Postby Bruce » Thu Feb 14, 2019 10:11 am
Is there a schedule for the next major (2019.x?) upgrade?
Bruce
Bruce
Postby Mark » Thu Feb 14, 2019 10:23 am
Hi Bruce,
Nothing official, but most likely later this year will be a FM 2020 release.
Postby terryhoho » Fri Mar 15, 2019 11:13 am
Will there be a Android app in future?
Can be independent or data sync with desktop.
terryhoho
Postby Mark » Fri Mar 15, 2019 11:16 am
Hi terryhoho,
There is a basic Android app now, which is used with the mobile/web interface. You can see the mobile/web tutorial. The data is provided by the desktop version, and you can view a snapshot of your current holdings with the client portal, or Android app.
Postby Bibliophile » Sat Apr 20, 2019 9:37 am
Hi Mark -
Perhaps working to enable CrossOver support (https://www.androidpolice.com/2018/11/1 ... romeboxes/) might enable you to skip development of a parallel effort? I’ve been considering replacing my slowly dying laptop (used for occasional travel and remote sessions) with a Chromebook, and Quicken and Fund Manager are my only two roadblocks to that plan...
BTW - love love LOVE Fund Manager. I’ve been using it for ~1 yr now, and am constantly amazed at the flexibility and quality of your software. Thanks.
Bibliophile
Postby Bibliophile » Sat Apr 20, 2019 9:46 am
Sorry - apparently it runs (4/5 stars): https://www.codeweavers.com/compatibili ... nd-manager
Bibliophile
Postby Mark » Sat Apr 20, 2019 5:50 pm
Hi Bibliophile,
Yes, I believe quite a few people have used it with Parallels, Wine, and Crossover. We don't officially support those platforms, but it should work.
