FM beta 2 feedback bug on UHD monitor
Postby mogul456 » Wed Sep 25, 2019 9:25 am
HI Mark: this problem with Samsung UHD monitor is still present in beta 2. when you open the data editor the data is garbled, the rest of the editor window looks fine. send me an email if you need a screen capture and i send you an example. thanks|Fred Cook
mogul456
Postby Mark » Wed Sep 25, 2019 9:35 am
Hi Fred,
I've just sent you an email, you can send any screenshots there.
Postby Mark » Wed Sep 25, 2019 11:59 am
Hi Fred,
Received your screen shot, thank you. The issue is your column widths are all too small. I'm not sure how they got that way, but you can resize them back to normal. At the top of the list are column headers. Between each column header is a divider that if you click/drag you can resize the columns. You can also double click on these dividers, and it will auto-size the column to fit the contents.
Postby mogul456 » Wed Sep 25, 2019 5:37 pm
thanks for your help|fc
mogul456
