Fidelity switch charges
Postby Gally » Sun Mar 22, 2009 1:49 pm
When I use transfer in/out to handle these movements the only mechanisim I have to takes account of charges is through the OOP value and market value fields.
Could you consider a field to consider a % switch cost i.e, 0.5% for transfer in as the transfer out could be handled at zero cost.
Is this teh correct process or should I use sell/buy?
RGDS Gally
Gally
Postby Mark » Mon Mar 23, 2009 8:11 am
Hi Gally,
I would suggest using transfers and not buys/sells, since you don't want to generate a capital gains event. Any fees associated with doing the transfer should be recorded as separate "Account Fee" transactions.
